Could this work?
Mike T., Swampeast MO
Member Posts: 6,928
Given a radiant burner--similar to Viessmann or kerosene heater.
40 mph exhaust????? or was it higher????
Why???
The combustion process is nearly perfect--to the point that it can be demonstrated as-is without concern for CO or other nasties.
Call me crazy, but the force of the radiation (speed of light) is impacting the exhaust!!!
Why on earth can't someone design a boiler with such a burner, a cast iron "main", a stainless "mid-transmitter" and stainless "afterburner"? Return temperature be damned.
Oh wait--my GOOD dreams are back--am I crazy?????
Why???
Could this work, It did!
The engine of the SR-71 was just such a burner! except it pushed a plane at + 3X's speed of sound. It even changed configuration when it went fast enough too. The Sun is also similar to what you ask for. So those engines exists. Have a nice day
Bigugh0
- 167 Indoor-Air Quality
