Low-E foil pros & cons
Looking for information about Low-e foil insulation. Are there any known problems, or is it a good product? Also do any of you recommend a different product? All replys are greatly welcome.
Jason
  • Ernie
    Ernie Member Posts: 94
    Low-E
    Have used it to insulate 2-1/2" steam mains with excellent results. Have also used it under wood shingles as a infiltration barrier and reflective insulation with excellent results. Slab Shield makes an excellent pad for rugs on concrete basement floors with out radiant heat. Use it to insulate cold water storage tanks to prevent condensation. Try any of these products and I am sure you will like them.
    Good Luck!
  • kevin_5
    kevin_5 Member Posts: 308
    It's a lot more fun under a slab than rigid foam
    Walking on it doesn't bust it up.
    If it blows away, you can drag it back, (in one piece) and it has the foil radiant barrier that I'm sold on. Also the plastic barbed staples work GREAT in the stuff. -I garonteeeee. Kevin
  • Duncan_2
    Duncan_2 Member Posts: 174
    What's your application?
    Its benefits and drawbacks really depend on what you want to use it for.
    You can get good results if you use it to reject heat, usually to cut down on heating loads in cooling applications.
    Check out these links, info and more reading (your tax dollars at work):
    http://www.eere.energy.gov/consumerinfo/refbriefs/vh3.html
    http://www.eere.energy.gov/consumerinfo/refbriefs/bc7.html
    The difference between what third party studies say, versus what manufacturers claim, is interesting, I think.
    If you want to really check it out, go to http://www.dogpile.com/ and do a search on "radiant barriers" in quotes - it treats it as a phrase, not as separate words.
