Cozy direct vented heater
I haved a cozy heater that is making a high pitched whistle when it's firing. LP unit,4-5 years old,customer can hear it on the opposite end of the house. Any ideas? Thanks Mike
  • jeff_25
    jeff_25 Member Posts: 110
    noise
    clean the buners and orifces and then check pressures jeff
  • Jeff_8
    Jeff_8 Member Posts: 7
    whistleing cozy
    The noise is called resonating. Cut the primary air and it should go away. Empire had this problem a few years ago and they sent a service notice out on how to fix it. I would play with the air so you cut it down just enough to stop the noise.
  • Larry_7
    Larry_7 Member Posts: 86
    Another possibility
    If a flexible connector is used it could be the source. Under certain flows they can whistle Dixie. The smaller diameter ones are the worse offenders I think. We've found this to be the problem on several gas log installs.
    Larry
