Cozy direct vented heater
Mikes mad pipes
Member Posts: 15
I haved a cozy heater that is making a high pitched whistle when it's firing. LP unit,4-5 years old,customer can hear it on the opposite end of the house. Any ideas? Thanks Mike
noise
clean the buners and orifces and then check pressures jeff0 -
whistleing cozy
The noise is called resonating. Cut the primary air and it should go away. Empire had this problem a few years ago and they sent a service notice out on how to fix it. I would play with the air so you cut it down just enough to stop the noise.0 -
Another possibility
If a flexible connector is used it could be the source. Under certain flows they can whistle Dixie. The smaller diameter ones are the worse offenders I think. We've found this to be the problem on several gas log installs.
Larry0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
