Just learning how to post pictures.
Frank_3
Member Posts: 112
In case you can't follow Alan's post, here's the HTML command, a little bit clearer I hope ...
<block><a href="http://www.heatinghelp.com" target="_blank">Link to Heatinghelp.com</a></block>
Sorry to take some space. I'm just trying to learn how to poost pictures here. Thanks for your patients
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
How do you add the link.....
to your website?
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Jeff, it's done by using HTML Code. The code is just below for you to view. If you would like to turn it into a link just put a space between the a & href and put one of these < before the a and this < /a > after your company here
ahref="http://www.climatecadvanced.com">The Name of your company here
Once you put the space it should look like this
You could do this where you store your personal settings or just type it when you wish to use it.
Is it spring yet? Man has this been some winter!
Alan R. Mercurio
Oil Tech Talk0 -
HTML
HTML
In case you can't follow Alan's post, here's the HTML command, a little bit clearer I hope ...Link to Heatinghelp.com
HTML
HTML
Obviously, change the document reference to your own web page instead of www.heatinghelp.com, and the text which says "Link to Heatinghelp.com" could be any other message.
The target="_blank" element tells the browser to open the linked page in a new window, rather than leaving the page you're currently viewing.
Lastly, at any time the folks at invision.net that host this forum could choose to disable this functionality. It can be a bit dangerous since a malicious user could embed other nasty stuff.
HTML
Which will end up looking like this ...
... in the finished product.
HTML
The target="_blank" element tells the browser to open the linked page in a new window, rather than replacing the page you're currently viewing.
Frank
I have no idea how you posted the code without it turning into a link? You Da Man! Thanks for the assistance
Alan R. Mercurio
Oil Tech Talk0 -
Pictures
Hi Alan.
That picture you posted was a bitmap - almost 1.5 MB. I use a great picture viewer available for free at
http://www.irfanview.com/
This has been around for years and real easy to use. You can change the format of a picture and resize in seconds. In the above instance you would save as a Jpeg and resize to 800 x 500 and you end up with a 30 KB file.
Noel Kelly0 -
Glenn Harrison Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Contractors
Crystal Lake,
Illinois0 -
Crystal Lake,
Illinois0 -
Crystal Lake, Illinois
Althoff Industries website0 -
Thanks, Alan and Frank...
I've been meaning to ask you how you do that. Just put the info to use (look at the bottom).
Thanks again!
Glenn Harrison, Residential Service Tech
Thanks Noel
Noel, Thank you for the tip on the site I'll check it out I'm sure it will come in handy. I knew the file was large as I mentioned this was my first time posting a picture once I seen how long it took to load I knew I had to do something different.
Dan also comfirmed for me that jpeg is the best way to go. So I did some messing around on the computer yesterday and learned how easy it was to convert my current pictures from bitmap to jpeg.
Thanks again for your help my friend
Alan R. Mercurio
Oil Tech Talk0 -
You're welcome Glenn
I say we give the bulk of the thanks to Frank though. He did the best job of showing how this works.
See you in Ohio my friend.
Alan R. Mercurio
Oil Tech Talk0
- 167 Indoor-Air Quality
