Tuesday H B Smith 8 series with aqua booster
Wethead7
Member Posts: 170
But manunal pressure switch is required on all Steamers here That includes the smallest vapor system. They also require two low water cut offs and a seprerate feed unit.
Second boiler this week
Smith 8 series 6 section with a 50 gallon aqua booster.One day in and out love the winter and the work but these long days are killers.0 -
You do really neat work. Glad to see pride in workmanship is still alive. I wonder what brand of pipe dope you use on the black iron pipe. Looks like the stuff I used years ago but havent been able to find recently.0 -
Not bad,
Not bad,
Joe. Even up off the floor. Bravo. Like the brass pigtails too. Should be many a year before they plug.
Why the manual reset pressuretrol? Didn't think manual reset was required until you hit 400 mbh input.
Do you have a direct line to the chiropractor?
Ron
I nyc manual reset required on any install 3 family or larger.This happens to be a 6 family house.0 -
Hmmmm,
Another Beckett. Joe, if you work by yourself, how do you do these jobs? Sub- contractors?0 -
Bill
I do not work by myself.There are 4 of us including me,my father my cousin and a long time employ and a good friend.As to the beckett when it is a rush job and easier to get a package boiler setup with a beckett I do.Also my father is a big beckett man and when he sells the job that is what we put in.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
