benifits to going steam to hot water?
Helgy
Member Posts: 12
I'm doing a bid right now on a steam boiler replacement in a residential home. Is there any benies in convertering to hot water? Let me know what you think.
Thanks, Helgy
Thanks, Helgy
There are many bennies, the bigget being a much quieter, more even heat in most cases. If you know what your doing with steam the existing system will work just great. The cost of the job will probably triple at least.0 -
Changing Apples to Oranges.
Unless you intend on removing all of the piping and radiators and starting anew, stay steam. Nothing wrong with a good operating steam system. There is way too much labor involved in just tring to see if the radiators can be converted to make worthwhile. Checking to see if they will hold 30+ psi of water, flushing all of the debris, drilling and tapping each one for a vent, adding a return pipe and trying to clean the main involves as much labor as removing the old system and installing all new components.
That is, unless you only charge $40 per hr.! ;-0
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
check out the info here
www.heatinghelp.com/newsletter.cfm?Id=220 -
Well Said, HB
steam systems are much easier, and less expensive, to fix than convert.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
