Flow Checks
it should work fine, but there is a phenomenon called laminar flow where you can get hot water flowing up and cold water flowing down, both happening through one pipe.
Whether or not it happens depends on your piping arrangement. Think like hot water and where you would go.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Dennis Bernier
    Dennis Bernier Member Posts: 3
    Flow Checks
    Is it possible to install flow check valves on 2 zones
    with one on the return side of the first zone and one on
    the discharge side of the other zone?
    Dennis
