Flow Checks
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
it should work fine, but there is a phenomenon called laminar flow where you can get hot water flowing up and cold water flowing down, both happening through one pipe.
Whether or not it happens depends on your piping arrangement. Think like hot water and where you would go.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Flow Checks
Is it possible to install flow check valves on 2 zones
with one on the return side of the first zone and one on
the discharge side of the other zone?
Dennis0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
