If I seperate sections of CastIron baseboard Radiatio
Nevin_2
Member Posts: 7
If I seperate a 6' length of cast iron baseboard radiation at the joint in the middle,
will I find pipe threads for male adapters, or gaskets, or tapered sleeves
connecting and sealing the two halves?
Thanks
Nevin
http://www.gardengrapevine.com/FurnaceOutdoor.html
Thanks
Nevin
If it's Slant/Fin
Metal push nipples are between the sections.
Noel0 -
NO
You wil find what are called push nipples and are fairly easy to seperate and remove. You will need a special tool to reinstall new push nipples if that is what you are doing.
It is important to follow the manufacturer's instructions for joining two pieces of cast iron back together.
Hope this helps.
Steve
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 167 Indoor-Air Quality
