gurgling pipes, water pressure and blleding
John Nelson
John Nelson Member Posts: 2
I have a water boiler system with all the pipes above the circulation pump. Two of the zones are making load gurgling noises. How can I blled the system from the main without decreasing the water level? If I decrease the water level, how can I add it without increasing pressure?
This all started when a local plumber replaced the pressure relief valve--they drained the system but have been unable to restore the pipes to the filled level.
