Radiant & Mixing Valve! (Jamie)
Jamie_6
Member Posts: 710
I'm starting a small radiant job on Monday and the heated space is about 60 feet (one way) from the boiler. Do you guys usually keep your mixing valves @ the board or should I put it in the room. (The only problem w/ that is it will take up more space then just the two manifolds)
Thanks,
Jamie
Thanks,
Jamie
You will have to move.........
the pump also, Jamie, if you put the mixing valve near the manifold. That means pulling wire and taking up even more room.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Not to mention it will be more difficult to do repairs in a finished room as oposed to a mechanical room or garage. I always just run pipe back to the boiler room. It has saved my company alot of money in the long run...0 -
Insulate the
supply and return to the manifols, 60 feet isn't to far.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
