Radiant & Mixing Valve! (Jamie)
Jamie_6
Jamie_6 Member Posts: 710
I'm starting a small radiant job on Monday and the heated space is about 60 feet (one way) from the boiler. Do you guys usually keep your mixing valves @ the board or should I put it in the room. (The only problem w/ that is it will take up more space then just the two manifolds)
Thanks,
Jamie
  • heatboy
    heatboy Member Posts: 1,468
    You will have to move.........
    the pump also, Jamie, if you put the mixing valve near the manifold. That means pulling wire and taking up even more room.
    hb
  • Josh M.
    Josh M. Member Posts: 359
    Not to mention it will be more difficult to do repairs in a finished room as oposed to a mechanical room or garage. I always just run pipe back to the boiler room. It has saved my company alot of money in the long run...
    hot_rod Member Posts: 28,098
    Insulate the
    supply and return to the manifols, 60 feet isn't to far.
    hot rod
