Steam leak found
jrc2905
jrc2905 Member Posts: 98
Well today I finally found the source of my problems. After fixing all the small problems I was still losing the water in this steam boiler. I stuck my head in the crall space which is all of ten inches high and found a section of the main line buried in dirt that was wet and had steam rising from it. I am going back with a long handled shovel and will remove the dirt from the bottom of this pipe to confirm the leak. Now this is a very old house and to repair this pipe I will have to remove sections of the floor to work from above the pipe. Is there any method of patching a steam pipe or is it a remove and replace job?
