Steam leak found
jrc2905
Member Posts: 98
Well today I finally found the source of my problems. After fixing all the small problems I was still losing the water in this steam boiler. I stuck my head in the crall space which is all of ten inches high and found a section of the main line buried in dirt that was wet and had steam rising from it. I am going back with a long handled shovel and will remove the dirt from the bottom of this pipe to confirm the leak. Now this is a very old house and to repair this pipe I will have to remove sections of the floor to work from above the pipe. Is there any method of patching a steam pipe or is it a remove and replace job?
I wouldn't try to patch it
it's probably weak all thru that area. Best replace it, and don't bury it this time.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
