zone-a-matic heating
Darren Beeler
Member Posts: 2
The problem I am having is that I am having to manually turn the open and close valves with a screwdriver to get the boiler to ignite. It't not the thermostat because it still regulates temp, but boiler will run nonstop unless I shut off entire unit. Then when it cools down I have to turn open and close valves agian to ingite. Any help would be great. Thanks
Darren Beeler
Darren Beeler
Darren Beeler0
- 167 Indoor-Air Quality
