Esso oil burner
most of these that I have found are Beckett burners with a Esso name only.They were red in color even the transformer was red.Set-up like a "AFG" with .75 80 A nozzle @ 100 psi F3 head and 3 3/8" plate and you should be fine. And don't forget a combustion test once done Hope this helps!John@Reliable
  • Ray Brusco
    Ray Brusco Member Posts: 1
    Esso oil burner
    I need a manual or any other advice on adjusting the following: Esso/Gilbert&Barker Economy oil burner model AT1, mounted on a Weil McLain boiler #67, model K-267 Series 1.
  • Jim_47
    Jim_47 Member Posts: 244
    Esso oil burner
    Ray
    Please tell me a little more. Is this residential, comercial? How many section boiler? Firing rate?
    ESSO reminds me of an older unit. Pre Exxon days.
    what is the condition of the overall boiler?
