Esso oil burner
John@Reliable
Member Posts: 379
most of these that I have found are Beckett burners with a Esso name only.They were red in color even the transformer was red.Set-up like a "AFG" with .75 80 A nozzle @ 100 psi F3 head and 3 3/8" plate and you should be fine. And don't forget a combustion test once done Hope this helps!John@Reliable
Esso oil burner
I need a manual or any other advice on adjusting the following: Esso/Gilbert&Barker Economy oil burner model AT1, mounted on a Weil McLain boiler #67, model K-267 Series 1.0 -
Esso oil burner
Ray
Please tell me a little more. Is this residential, comercial? How many section boiler? Firing rate?
ESSO reminds me of an older unit. Pre Exxon days.
what is the condition of the overall boiler?0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 925 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
