set tub on structolite or cement on tar paper?/stapleup undernea
ken_6
Member Posts: 33
was told when setting tub on structolite or cement(so acrylic doesn't skwoosh)to put tar paper between wood and cement/structolite. is this an issue with stapled up.
I read some place
that tar paper and radiant heat are not a good mix, gives off odor.0 -
If you have to use paper
use a building paper that has no smell when it gets warm. There have been horror stories about the smell of tar paper when radiant is heated up.
Art0 -
Vapor barrier
We use 6mil polyethelene.Have had no problems or odors0
- 167 Indoor-Air Quality
