set tub on structolite or cement on tar paper?/stapleup undernea
ken_6
ken_6 Member Posts: 33
was told when setting tub on structolite or cement(so acrylic doesn't skwoosh)to put tar paper between wood and cement/structolite. is this an issue with stapled up.
  • zeb_3
    zeb_3 Member Posts: 104
    I read some place
    that tar paper and radiant heat are not a good mix, gives off odor.
  • Art Pittaway_2
    Art Pittaway_2 Member Posts: 80
    If you have to use paper
    use a building paper that has no smell when it gets warm. There have been horror stories about the smell of tar paper when radiant is heated up.
    Art
  • Earthfire
    Earthfire Member Posts: 543
    Vapor barrier
    We use 6mil polyethelene.Have had no problems or odors
