Water conductivity for probe type lwco (steam)
Mark A. Custis
Member Posts: 247
9000.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=268&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Water resistance
Anyone know what the proper resistance should be for the
water in a steam boiler using a PS-802 (McDonnell&Miller)
probe type lwco? Instructions mention that conductive liquid
is required. Would it be better to use a float type lwco in
a steam boiler, rather than the probe type?
Thanks for now, Mike Lampkin
water conductivity
Mike, water is a conductive liquid. Probe/electronic LWCO's work great and are less troublesome from a maintenance standpoint. Just make sure you make cleaning the probe annually part of the boiler service tasking. They do get dirty and can fail if too much crud gets built up on the probe.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 27 Recall Announcements
