Frist drop header pics..David s
hope these come out ok not to good at the pic thing yet lol
  • EricR_2
    EricR_2 Member Posts: 43
    Hate to sound ignorant
    but what are the benefits or reasons for the
  • EricR_2
    Hate to sound ignorant but
    what is the purpose for drop headers and what are the benefits or reasons for or against? Thanks.
    Eric
  • David Sutton
    David Sutton Member Posts: 82
    drop headers...
    are mainly used if you donot have the celling hight to forfill your 24" height requirement between the water line and the bottom of the header so you drop down and build your header hope this helps . but iam sure one of the other fine gents will explain it much better than i can ... David
  • Great pipework Dave
    I bet the time saved making the joint between the 2 headers is reason alone to use a drop header from now on . Did you get to fire it up today ?
  • David Sutton
    firing up today...
    i should have it going by noon today, still got to add steam traps as well, the two guys i have with me, have not done steam before, they are learning real fast and are doing well,the kid in the last pic is russ, just turned 21. and is willing to learn and work smart. see ya DAvid
  • nice header, Dave.
    It actually costs less to do it like that, considering the time savings.
    Noel
  • David Sutton_2
    David Sutton_2 Member Posts: 63
    looks good
    piping job came out very nice... t.m.
  • Jamie_6
    Jamie_6 Member Posts: 710
    WOW
    Nice looking pipe work! That must have taken days! I would like to know how you get those pipes together w/out having any teeth marks from your wrenchs?
    Jamie
  • David Sutton
    thank you jamie
    it took one and 1/2 days to do all the piping, 1/2 a day of that was taking it back apart to repipe it to fit on the blocks oh well. when i pipe in the fittings i frist wick them then teflon tape them,then gasoila pipe dope. the fittings spin on real smooth and tighten up real tight and i never put a wrench on a pice of pipe , only on the fittings, thank you again for the compliment.... David S
