Installing a basement radiator
LongTownFellow
Member Posts: 14
Hi folks, the owner of a ranch house has added a bathroom to the unfinished, unheated basement, and would like to install heat in the new bathroom. Heat to the house is supplied by a diverter T hot water system, pump away, 1 inch supply main, 1/2 inch branch connections to 7 cast iron baseboard radiators, with diverter Ts on the return side, serving the main floor. I was going to recommend that a 6 foot cast iron baseboard radiator be installed in the basement bathroom.
Will 2 diverter Ts cut into the 1 inch main loop serving ½ inch supply lines work for this application, or should a new zone be added to the boiler (Utica USC4 w/ taco 007 circulator)? The supply line from the main would be 4 feet horizontal and 7 feet vertical (down), and the return from the radiator would be 7 feet vertical (up) and 20 feet horizontal. Thankx.
Suggestions.
Personally I would go with a new zone for this section. The diverter T's with the new piping and new radiation may prove too much for the circulator.
Better safe than sorry.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
