What is this?
Jackchips
Jackchips Member Posts: 344
it's a strainer, Alan, that has been partially plugged and this is contributing to the lack of flow?
  • Jon LaChance
    Jon LaChance Member Posts: 1
    What is this?
    This is installed in a 1950's fire station. To me it looks like a check valve. It is installed on the supply side of a hot water system.
    Line size is 1-1/4" . It has the words "open" and "Run" on it.
    We are experiencing problems getting proper flow thruout the building.
    Thanks a bunch
    Jon LaChance
    Vierbicher Associates
    Madison, WI
    jlac@vierbicher.com
  • Alan R. Mercurio
    Alan R. Mercurio Member Posts: 588
    Looks like a flow valve
    I would think in the Run position it would allow water to pass when the circulator is operating. and in the Open position it would allow water to flow via graqvity if a circulator were not working.
    Your friend in the industry,
    Alan R. Mercurio
    Oil Tech Talk
  • Jackchips
    Any chance
    it's a strainer, Alan, that has become partially plugged and that is contributing to the flow problem?
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    It's just a Flo-check,
    old style, but tha's all it is.
    I'll see if I can find a piece of lit on it.
