What is this?
Jackchips
Member Posts: 344
it's a strainer, Alan, that has been partially plugged and this is contributing to the lack of flow?
What is this?
This is installed in a 1950's fire station. To me it looks like a check valve. It is installed on the supply side of a hot water system.
Line size is 1-1/4" . It has the words "open" and "Run" on it.
We are experiencing problems getting proper flow thruout the building.
Thanks a bunch
Jon LaChance
Vierbicher Associates
Madison, WI
jlac@vierbicher.com0 -
Looks like a flow valve
I would think in the Run position it would allow water to pass when the circulator is operating. and in the Open position it would allow water to flow via graqvity if a circulator were not working.
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
Any chance
it's a strainer, Alan, that has become partially plugged and that is contributing to the flow problem?0 -
It's just a Flo-check,
old style, but tha's all it is.
I'll see if I can find a piece of lit on it.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
