Heil Furnace
furnace. I am looking for a site to download PDF file on this furnace to help a homeowner with a no heat. I tried Heil site and International Comfort Products no service literature available. Can anyone help me out?
Heil
I can't help with a manual but I have the 80% in my shop and put a 90% in for my Dad's house. The ones I have are smart valve with hot surface. Have them check for the ignitior glow after inducer ramp up and be sure the presure switch is made. I have had some problems at about 5 years with the ignitiors failing and the smart valve seems to lock out all function till the correct resistance is on the ignitor. I do not recall the ohm reading for a good one but the ones which failed for me showed open even on the high scale. Also if it is on LP you may want to get one of the new stainless pilot orfices to control the orfice corrosion which restricts the gas flow (had to clean mine every year).0 -
Timmie, try...
www.heildlr.com/pfindex.asp
and click on product info then service manuals and see if what is in there is what you need.
Glenn Harrison Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Contractors
Crystal Lake, Illinois0 -
Thanks Glenn
I will give it a try.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
