looking forElectric stair walking hand cart
steve_19
Member Posts: 13
Try LP International they carry PowerMate electric stair climbers. Call 800-697-6283 and they'll send out some information, or go to their web site at www.powermate.info
looking to buy new......
need a electric hand cart, anyone have suggestions on a good name or a web site i can go to. thank you for your help .. David0 -
try innovative moving systems 1 800 619- 0625 www.lectrotruck@excel.com i have moved in 809 and 810 burnhams with 2 helpers down stairs old oil tank 2 person no strain if you buy it make sure you buy the 1/2 strap for water heaters and also the off road rubber tires web sight has a movie i think jeff0 -
stairclimber
I've used both the lectrotruk and power mate units. If you're installing in all conditions and over all kinds of terrain, go with the lectro truk. It has better "big wheels" and manuverability. The Power Mate is good for solid ground and concrete/blacktop, but a real bother on turf and snow/ice.
http://www.escalera.com/ Gets the best reviews from folks I have talked to. Get the larger wheels and tires for use on lawns and construction sites.
hot rodBob "hot rod" Rohr
escelera
the short one with the forks is great for old boiler sections they slide right on. you can crank the forks 52"
to load /unload boilers into truck.the other brands seem to require awkward looking up and down movement between
cycles the escelera stays in roughly the same position
throughout. @ first i had trouble going down the stairs (going up is easy) after calling factory I realized center
of gravity was to far away from me.please dont make a new 8 sec boiler the first thing you try it on,like i did.
"big wheel kit" a must,fork motor not needed..good luck....paul lessard0 -
Thank you guys !!!!!...(nm)
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
