looking forElectric stair walking hand cart
steve_19
steve_19 Member Posts: 13
Try LP International they carry PowerMate electric stair climbers. Call 800-697-6283 and they'll send out some information, or go to their web site at www.powermate.info
  • David Sutton_2
    David Sutton_2 Member Posts: 63
    looking to buy new......
    need a electric hand cart, anyone have suggestions on a good name or a web site i can go to. thank you for your help .. David
  • jeff_25
    jeff_25 Member Posts: 110
    try innovative moving systems 1 800 619- 0625 www.lectrotruck@excel.com i have moved in 809 and 810 burnhams with 2 helpers down stairs old oil tank 2 person no strain if you buy it make sure you buy the 1/2 strap for water heaters and also the off road rubber tires web sight has a movie i think jeff
  • Al Letellier
    Al Letellier Member Posts: 781
    stairclimber
    I've used both the lectrotruk and power mate units. If you're installing in all conditions and over all kinds of terrain, go with the lectro truk. It has better "big wheels" and manuverability. The Power Mate is good for solid ground and concrete/blacktop, but a real bother on turf and snow/ice.
    hot_rod Member Posts: 25,327
    http://www.escalera.com/ Gets the best reviews from folks I have talked to. Get the larger wheels and tires for use on lawns and construction sites.
    hot rod
  • paul lessard_3
    paul lessard_3 Member Posts: 186
    escelera
    the short one with the forks is great for old boiler sections they slide right on. you can crank the forks 52"
    to load /unload boilers into truck.the other brands seem to require awkward looking up and down movement between
    cycles the escelera stays in roughly the same position
    throughout. @ first i had trouble going down the stairs (going up is easy) after calling factory I realized center
    of gravity was to far away from me.please dont make a new 8 sec boiler the first thing you try it on,like i did.
    "big wheel kit" a must,fork motor not needed..good luck....paul lessard
  • David Sutton
    David Sutton Member Posts: 82
    Thank you guys !!!!!...(nm)
