Indirect Heat Question
jack_4
jack_4 Member Posts: 43
Indirect heat question
Since the absence of heat is COLD, and it is very cold here, (8-10 degrees) I’ve had reason to look at outside air thermometers a lot recently.
Out of the 5 fairly high-end units I have every one is off a degree or 5 from the others. They are all adjustable.
I want to move them all to the same spot, let them stabilize and adjust them all to read the same.
Question?? How do I determine what the correct air temperature is at the time I make the adjustments?
Do I let a glass of water come to temperature and use a fever thermometer to assess the water temperature?
Do I assume that my Honeywell PC8900 outside temperature reading is the most correct and use it as the reference?
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Temp in a container
    half filled with ice and half with water will be 32°. Accurate enough for laboratory use.
  • jack_4
    Water to air
    How does that make the leap from a liquid reading to an air reading?
