Indirect Heat Question
jack_4
Member Posts: 43
Indirect heat question
Since the absence of heat is COLD, and it is very cold here, (8-10 degrees) Ive had reason to look at outside air thermometers a lot recently.
Out of the 5 fairly high-end units I have every one is off a degree or 5 from the others. They are all adjustable.
I want to move them all to the same spot, let them stabilize and adjust them all to read the same.
Question?? How do I determine what the correct air temperature is at the time I make the adjustments?
Do I let a glass of water come to temperature and use a fever thermometer to assess the water temperature?
Do I assume that my Honeywell PC8900 outside temperature reading is the most correct and use it as the reference?
Temp in a container
half filled with ice and half with water will be 32°. Accurate enough for laboratory use.0 -
Water to air
How does that make the leap from a liquid reading to an air reading?0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
