the better indirect
ta finnegan
Member Posts: 121
Water quality for sure is critical with coils.
Tank in tanks are nice, but for my money I have found fewer products that perform as well, given proper installation, as Crown Boiler's indirects. Good Company and good people.
Just one man's experience.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=251&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
the better indirect
can anyone tell me which style indirect is more efficient
a tank w/in a tank or a coil w/in a tank. given everything else is equal. (the boiler,circulator and surface of
the tank and coil)
thanks,
jay.0 -
indirects
Jay, check the recovery rate of the tanks you are considering. The gallons per hour/BTU rating of the boiler says it all. We have found that the tank within a tank make more hot water that the coil type, and I've never had to replace one yet, but could start a museum with the failed coil type that we've replace. It also has a lot to do with the water conditions in your area. We plug up a lot of coils here.
indirect
we like the bock indirects been useing them for a while and they are lifetime waurrantee as long as original owner put in. excellent product no leakers yet. jmo jg.0 -
better indirect
We like using the amtrol. It is a tank with a coil in. We never had a coil go out yet. The same water goes through, just like on baseboard. They also have a very fast recovery rate.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
