Riser to nowhere ?
Bobby D.
Member Posts: 38
My one pipe system has a riser about mid main that goes through the bathroom and is capped solid in the attic.
It goes from 1" pipe from the feed off the main, to a 2" pipe on the riser, up into the bathroom.
In the bathroom is a side tapping off this riser with a spring loaded adjustable nut that can close or open this tap and attachted to that is a standard radiator vent that spews water when the pressure is up, and allows the riser to get hot to heat the bathroom.
Was this riser an additional attic feed for heat that was never connected to a radiator ?
Should the solid cap be changed and made into an additional main vent on a riser to solve the spitting vent problem ?
Any thoughts on the function of this riser ?
P.S . this is no other radiator or heat source in the bathroom.
Dual-purpose riser
That's definitely your bathroom radiator. Sounds like the vent has gone bad- replace it with a standard radiator vent.
Since they took this riser into the attic my guess is they were providing for a room to be built up there. Though the 1-inch feed from the main sounds a bit small.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
