BTUs for cast iron baseboard
ta finnegan
Member Posts: 121
Check Weil's website and your local dealer, this info should be readily available, but make sure you tell them about the temp.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=251&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Cast iron baseboard BTUs
Does anyone have an idea of how many btus a section of Weil McLain cast iron radiator kicks out at 140 degrees? Im considering putting some of these in my basement from a salvage dealer but dont know how to compare with radiators. Can get sections in 2 foot increments for $15/foot. On the flip side, can get radiators for $14/section regardless of height/# tubes. Any feedback appreciated. Ive calculated my needs, have 2 rooms which need just under 2000 Btus/hr.
Thanks, Patrick
Dimensions
Is this baseboard 7 or 9 inches tall? And does it have slots along the top or not?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
