BTUs for cast iron baseboard
ta finnegan
ta finnegan Member Posts: 121
Check Weil's website and your local dealer, this info should be readily available, but make sure you tell them about the temp.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=251&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Patrick_7
    Patrick_7 Member Posts: 1
    Cast iron baseboard BTUs
    Does anyone have an idea of how many btus a section of Weil McLain cast iron radiator kicks out at 140 degrees? I’m considering putting some of these in my basement from a salvage dealer but don’t know how to compare with radiators. Can get sections in 2 foot increments for $15/foot. On the flip side, can get radiators for $14/section regardless of height/# tubes. Any feedback appreciated. I’ve calculated my needs, have 2 rooms which need just under 2000 Btus/hr.
    Thanks, Patrick
    Steamhead Member Posts: 18,502
    Dimensions
    Is this baseboard 7 or 9 inches tall? And does it have slots along the top or not?
    Consulting
