humidfier for a \"magic pak\" furnace
jeff_25
jeff_25 Member Posts: 110
you could have a selfcontand aprilaire installed
  • can a humidifer be installed on a \"magic pak\" furnace?
    I it possible to put a humidifer on a magic pak furnace?. It is an all in 1 unit ( heat and ac ). I live in a condo and it is in a closet. the hot air goes out from the top and the cold air return is under the floor and enters the unit from the bottom. Is it possible to install a humidifer and where? thanks!
  • can a humidifer be installed on a magic pak furnace
