humidfier for a \"magic pak\" furnace
jeff_25
Member Posts: 110
you could have a selfcontand aprilaire installed
can a humidifer be installed on a \"magic pak\" furnace?
I it possible to put a humidifer on a magic pak furnace?. It is an all in 1 unit ( heat and ac ). I live in a condo and it is in a closet. the hot air goes out from the top and the cold air return is under the floor and enters the unit from the bottom. Is it possible to install a humidifer and where? thanks!0 -
can a humidifer be installed on a magic pak furnace
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
