ventori systems
paul_14
Member Posts: 16
how do they exactly work?
Pretty broad question
But here's a start:
Definition of "venturi" - a smoothly tapered restriction in a tube that reduces fluid pressure at the restriction.
(Source: Air Conditioning Heating & Refrigeration Dictionary, 2nd Edition, Tim Zurick)
I could teach a four hour course on the Venturi theory, the math associated with it, and it's HVAC applications.
Do you have a more specific question?
Tom Meyer
Senior Designer/Trainer
Precision Hydronics
www.precisionhydronics.com0 -
are venturi tee's anything like monoflow tee's?is it the same type of system?0 -
monoflow tee's & venturi tee's...
It is my assupmtion from looking at them under a few different applications that:
Monoflow Tee -- is to be used in a one direction flow ( of anything)with the taking of a portion of the one direction flow to flow to another direction
Venturi Tee -- is to be used in an application where two flow combine into one flow in the same direction
I hope this helps
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 853 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
