Counterflow steam line
Franky
Member Posts: 5
I have to replace a buried steam line.
I have two options.
1. Run a four-inch line and install a condensate tank at the end of a 100 foot run.
2. Run a six-inch(?) counter flow line and install the tank at the beginning of the line.
Option #2 presents much easier access for the tank.
How far is too far for counterflow????
How much does the line need to be upsized???
Developed lenght is 100 feet.
The line has four ells and take the shape of a "U"
Thanks.
I have two options.
Thanks.
I could
and I did, though only 2", serving a small addition. It was over 100 feet long.
Noel0 -
How Much...
...steam are you moving? What's the pressure?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
