Correct thermostat for 1960 Smith boiler
Glenn Harrison
Member Posts: 405
Peter, your Magic Stat should have a cycle rate adjustment on it. The cycle rate is factory set for 6 cycles per hour and should be set for 3 cycles. Normally, if I remember correctly the adjustment is to turn the "A" screw on the back of the thermostat out one turn to change the cycles to 3 per hour, but double check your installation instructions to be sure.
Glenn Harrison Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Contractors
Crystal Lake, Illinois
Correct thermostat for 1960 smith boiler?
I have a 1960 Smith boiler and a 6000 sqf building. And I am using a programable magic stat thermostat. I normally leave the heat at 65f durring the morning and on some days the boiler will kick in every 5 minutes is this normal.0
- 167 Indoor-Air Quality
