radiant roof
Mike T., Swampeast MO
Member Posts: 6,928
I believe that's what they're called. They are designed to hold snow on steep roofs--particularly slate/metal etc.
Trying to melt it (and keep it melted) might be futile. If you melt it off the roof, it will freeze in the gutters, eventually overflow and then freeze on whatever is lower (the porch roofs) where icicles in the "deadly stalactite" range might form.
Link below should be of use.
http://www.traditional-building.com/article/snowg.htm
radiant roof
I have a customer that wants a roof melt system. He does not want the electric cable type because it's ugly. (you have to know the guy!) He is considering some sort of radiant type system, being he likes the one I installed in his house. Does any one have a suggestion for this? I'm thinking just a staple up under the roof with a simple set point controller, on a seperate boiler with glycol, and let 'er rip! Fuel consumption is not a huge factor, being the short time it will run. Looking forward for input!
Thanks
Andy Morgan0 -
You know Andy I have been thinking about that alot. Put tubes in the roof bays and you could use them for roof melt and then in the summer reverse it and use it as solar colector to use for Hot Water. Just use a HX
John Jr0 -
Bizarre
Why?
Ice dams? I pray not for appearance--what a terrible waste of fuel! Just like an igloo, snow on the roof in snow country actually insulates because it's 32°.
If customer insists would suggest Thermo-fin. One straight strip per rafter bay if on 24" centers; one zig-zag strip (skew each 8' piece oppositely) every other bay if on 16"???
i was thinking
of a radiant panel system like quick trac right underneath the singles for a solar collector. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
plates under shingles?
Who's going to re-roof the house in the future????
somebody who is
very careful. but you would be able to see the pex just like when you install hardwood flooring over panels. the roof might last a lot longer if it is a lot cooler. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
reroof
It's a metal standing seem roof, and the problem is snow coming off a very steep roof and landing on the four very shallow porch roofs. With the past storms, the snow covers some windows and the owner is not interested in shoveling them off.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
