Finding tubes in concrete
RichF
Member Posts: 3
I'm in the refrigeration buisness and we install tubing in sub slabs of freezers to protect the ground from freezing. On a current job, we need to locate the tubes we just installed so "bollards" can be installed thru the sub slab. What do you guys use to find your tubing?
This system is now full of glycol and can be circulated but our heat source will not be any warmer than the floor is right now (about 55 degrees).
The best way
I know is to find a way to turn the heat up. Cold floor crayon or marker and a mop. Wet the floor, turn on the heat and watch it. As the floor above the hose starts to dry in stripes, mark it. I think you will need more than 55* though.0 -
I've
hired an infrared expert. Run warm water through the tubes and look through his camera and you will be able to see the tubes. Pretty cool toy. (very expensive, I checked)
Art is right, the water method is probably the fastest and easiest but probably will not work @ 55*. However you can let the floor go cold for a day and then turn the heat back on and find the tubes with a hand held radiant thermometer. You can get these at most supply houses for under a hundred dollars and they have a thousand uses.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
