PDAs
larry
Member Posts: 91
On the Palm platform there is a great *freeware* application called HandyShopper. Although it's used by many people to create shopping lists for the supermarket, you can create your own database with heating/plumbing parts. As you select the parts (putting in the first few letters) it temporarily moves the item from the primary list to a seperate list (called items needed). You can put in pricing info for each item, and have it total the list. A couple of years ago I checked out all the products of this sort, and though HandyShopper to be a class by itself and the price is certainly right. The other popular database platform for palm is thinkDB (now called SmartList to Go by Dataviz). With this you could design your own database application that does exactly what you want.
Software for pda
What software do you use and for what application do you use it for . I would like one to make lists ,that I would enter the first few letters of a word then the rest of the word would pop up ,to be used for listing material used on a job . Maybe it would have prices attached as well . What else do you use your pda's for besides date and address .
Thanks for the help.
Mitch0 -
WordComplete
is the program that someone beamed to me to do exactly what you're asking. I do the same and I've also added custom words so that I don't have to graffiti everything in. I don't know where to get it though, maybe try an internet search. I also use the memo function to keep track of jobs for billing as well as past due balances so that I can collect from a client without having to call the office. Good luck!0 -
P D A's have alot to offer...
Which unit are you using? Is it a Palm or one of the
other units available using Windows CE or other format.?
I have been exploring the idea of Hydonics user specefic software package if there would be enough interest. I have
always thought Hydronic people, particularly the group on
" The Wall " are FORWARD THINKING people.
Thanks
Big AL0 -
PDA
I'd be lost without my Sony Clie; uses the palm platform and I don't have any fancy programs. The bundled software takes care of adresses, calendar and to do lists and I use the memo part to keep track of all our current jobs (contact information, permit numbers, notes, etc.).
I've modified the custom fields to accept:
1) boiler model and serial number
2) circulator model numbers
3) type of zone valves
so that when a customer calls up, I know what equipment they have and can stock my truck before going over.
In the notes field, I keep track of the service history.
Now THERE is a scary mental image...
...a HVAC tech, bluejeans hanging low enough to see the "plumber's crack", a oily rag hanging out of his back pocket, tool belt around his paid-for beer belly, with a pipe wrench in one hand and a Palm Pilot in the other.
Holy Cow! That's me in a mirror (years ago).
8-P
Tom Meyer
Senior Designer/Trainer
Precision Hydronics
www.precisionhydronics.com0 -
Don't know
one PDA from another but I do wish you would buy a Palm so my stock will recover. :-)0 -
pda shortcuts
There is already a way to do what you want if you have a Palm. 1. Tap the house in the lower left of screen. 2. Tap the little arrow upper right of screen. 3. Tap system. 4. Tap Prefs. 5. Tap the little arrow upper right of screen again. 6. Tap shortcuts. 7. Tap new. 8. Where it says shortcut name enter the first few letters of a word. (You only need one letter here.) 8. Where it says shortcut text write the word.
Now when you want the word write a loop-dee thing like a script small e in the graffiti area. The loop-dee thing will appear in whatever you have opened Memo date book to do what ever. Then write the single letter (your short cut) and the full word will appear. Have fun
Software for PDAs
You can download a lot of free software for PDAs from www.cnet.com or www.zdnet.com
Both have searchable indexes of programs. There may actually be something there, ready made, that will work for you. I picked up a couple of games for my older palm(gives me something to do at lunch) and they work fine. You need to know your operating system to get the right stuff.0
- 120 Geothermal
