Two Tiger Loops on same line feeding two burners
jweglarz@hotmail.com
Member Posts: 16
Will having two tiger loops on the same line (1/2 inch) feeding two burners work?
-Joe
-Joe
Why.....YES!!!!
Pipe one tiger loop into the incoming line and then tee the supply and return lines to the pumps....
unless you have some big a** burners it will work just fine!!!!!
Have had three burners running @ 1.65 running off of 1 Tiger Loop and they worked just peachy!!!!!
Floyd0 -
that's
not how it's done. 1 Loop will typically supply 2 residential burners.
tiger loop
whats a tiger loop?0 -
Er, better check the box
Tigerloop now has a white paper in the box stating that only one burner be feed from it. If using 2 burners, 2 Tigerloops must be hooked together in series.Of course, I have dozens out there hooked to 2 burners for years, just like alot of us have done.I think its more of a large capacity (read commercial) thing.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
