Two Tiger Loops on same line feeding two burners
Will having two tiger loops on the same line (1/2 inch) feeding two burners work?
-Joe
  • Floyd
    Floyd Member Posts: 429
    Why.....YES!!!!
    Pipe one tiger loop into the incoming line and then tee the supply and return lines to the pumps....
    unless you have some big a** burners it will work just fine!!!!!
    Have had three burners running @ 1.65 running off of 1 Tiger Loop and they worked just peachy!!!!!
    Floyd
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,080
    that's
    not how it's done. 1 Loop will typically supply 2 residential burners.
  • paul_14
    paul_14 Member Posts: 16
    tiger loop
    whats a tiger loop?
  • B. Tice
    B. Tice Member Posts: 206
    Er, better check the box
    Tigerloop now has a white paper in the box stating that only one burner be feed from it. If using 2 burners, 2 Tigerloops must be hooked together in series.Of course, I have dozens out there hooked to 2 burners for years, just like alot of us have done.I think its more of a large capacity (read commercial) thing.
