Gentlemen I need suggestions
Lee_2
Member Posts: 48
Need your help gentlemen with a small problem. I have a Ridgid 1224 pipe threader. Since most of you know, I thread a considerable amount of 1-1/4" pipe threads. I have recently begun to purchase new dies for the threader too often because midway through the threading process a chunk of the thread is chopped/gouged out. Doesn't happen all the time, but seems to happen more often. I use Ridgid stainless cutting oil, the dies are installed correctly, the machine is kept in top condition. Ridgid suggested the batch of pipe I received might be the problem. I tried different pipe. Still does it. Ridgid has no suggestions. Does anyone have any suggestions/previous experience? The closest repair is some distance, and I have to take the machine there, and the machine is no small hand tool. Help!!
Pipe
Lee,
Are you positive that your steel pipe is DOMESTIC made, as opposed to foreign made? This will make a difference.
Bill0 -
Also
be sure to use the dark cutting oil, tried the other stuff and it does NOT work at all!! cannot remember but i believe it is hercules brand !!
Murph'0 -
Wheatland Pipe Company supplies my pipe0 -
Dark cutting oil is no good. I use High Speed Dies.0 -
I
have noticed this too, Lee. I keep the dies a tad loose in the head for a kind of "self-adjusting" action, use dark oil with sulfur base. I have been cleaning the dies meticulously after each thread. Seems to help. One thing I learned is that the pipe itself must be really supported/true upon threading..even a small wobble can exert unwanted pressure on one side of the cut, and tear out threads.
Some days I toss 3-4 attempts and want to beat the machine senseless. Other times things go fine. Go figure-
This is related to a previous post I bet....
That was very educational. I started it and I think it was titled..Poor quality pipe and fittings...made in the USA. I have found Wheatland pipe to be of poor quality as are most other makes whether domestic or not. I use Sharon Tube pipe exclusively now, all other brands I have come across seem to have alot of brittle material in the steel and cause threads to tear out and die to chip when I am threading manually.
Boilerpro0 -
i think you can use the dark oil on high speed dies i have troubles with old or watered down oil good luck also try reseting or dies in the holders jeff0 -
Pipe
we have had the same experience and I beleive its the pipe. I think even domestic pipe is not being made as well as it was. We can do six threads fine and then gouge out a big chunk.
Scott
