Icing on Top
Neil Andrews
Member Posts: 14
Every since we have started having the Deep Freeze here in North Jersey.
I have noticed that I have some icicles hanging from the top of my chimney cap, which I have never noticed before.
I have a WM EG-45 gas steam boiler that was replaced 2 years ago, the boiler water level has stayed pretty constant and boiler has not called for any makeup water.
Since this is the first time I have ever noticed this, is this phenomena normal?
If it is not normal what could it be?
At first I thought that I may have a crack or leak in a boiler section, but the water level stays constant. ???
Thanks
Neil
Thanks
Neil
Blow Down
Have you "blown down" the water feeder/low water cutoff regularly? (Once a week in heating season for the first year of a steam boiler's new life), once a month thereafter in heating season, once every 2 weeks preferred. Dan has addressed commisioning steam boilers and proper "Blow Down" in his book "The Lost Art of Steam Heating" It's where the answers are.
Blow down
Thanks for your reply Paul.
Blow down has been done regularly. I have a copy of Dan's book. I don't know if you mis-understood my question or concern.
The boiler water feed system is working properly. What I am concerned about is the icicles that are forming on the top of the chimney cap, which leads me to believe there may be water vapor escaping up the chimney.
Since my boilers water level is staying constant and the boiler is not taking on any makup water. I can assume the boiler does not have a hole or crack or leak in any of its sections.
If the boiler is not loosing water or steam up the chimney.
Where is this water vapor that is forming into icicles coming from??
Thanks
Neil0 -
Water is...
...a large portion of the product of combusion. Water vapor is what causes the concerns of condensation in the boiler/flue. While I haven't noticed icicles from chimney caps before it might be considered {normal} in extremely cold weather.
Am not sure about steam boilers, but the increases in efficiency of even plain cast iron boilers have made their use in large, unlined brick flues highly questionable. I believe venting a new boiler/furnace (even a non-condensing model) to an old flue is strictly against code in some areas. Old chimneys with one or more sides exposed to the weather are supposedly the most vulnerable--heat in the house proper helps somewhat with internal chimneys.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
