Steam radiator Grill or Cover
Tim_6
Member Posts: 4
I have a 1930s era home that had the steam radiators PLASTERED into the walls. There is a small grill about 24 inches up the wall to discharge the heat and a base-board cut-out to let in cool air.
I am remodeling the kitchen, dining room, and office, and have everything down to studs. As you might imagine, I do not want to plaster these things back into the new wall. Does anyone know of a company that makes flat grilles or convers that can mount flush to the wall to cover the radiators? I am guessing they will also need a cool air intake in the bottom, and then can be screwed to the framed-in radiator.
A Massachusetts-based company would be nice, but is not required.
Thanks.
Thanks.
radiator covers
try newton shade and blind co. in watertown ph. no. is 617-924-4200 they sell radiater covers they should be able to help
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 120 Geothermal
