Controller Preference
I'm curious to see what everybody's pref would be for a home heating only system controller. heat is oil-fired Crown Freeport (80000 Btuh), 4 baseboard zones with automag zone valves, and 1 DHW indirect Crown super-stor with automag zone valve. The new controller would incorporate (1) priority zone (DWH) and also utilize outdoor reset.
  • Boonierat
    Boonierat Member Posts: 58
    I've had good results using the Taco ZVC406-EXP series of zone valve controllers.
    Has a built in transformer large enough to accomodate all your zones, prioritizes the domestic hot water and the EXP version of the controller will afford you the options of boiler re-set, Variable speed injection, 2-stage boiler re-reset, and some other bells 'n whistles. The kewl part is that bells 'n whistles are either plug 'n play cards, or molex connectors. Keeps wiring simple.
  • John Penwarden_2
    John Penwarden_2 Member Posts: 18
    Typically how much do they run?
    I like the looks of the board!
