Tile vs. Wood vs. Carpet
gene
gene Member Posts: 1
In a gypcrete application, what are the maximum supply temps for ceramic tile, carpet and hardwood flooring?
Also what is the recommended TD on a Viessmann's divicon (between supply and return)? I'm running about 14 degrees F TD. GB
    hot_rod Member Posts: 25,396
    In Gypsum pours.........
    the water temperature limit is 145°, give or take a couple. It doesn't matter whether it's tile, wood or carpet. The limiting factor is the stability of the gyp.
    The Delta T for the Divicon is whatever you need it to be. With the multi-speed pump, I have Delta Ts from 10° to 25° depending on the application.
    Warm Regards,
    heatboy
    "Expert in Silent Warmth" ™
