Tile vs. Wood vs. Carpet
gene
Member Posts: 1
In a gypcrete application, what are the maximum supply temps for ceramic tile, carpet and hardwood flooring?
Also what is the recommended TD on a Viessmann's divicon (between supply and return)? I'm running about 14 degrees F TD. GB
In Gypsum pours.........
the water temperature limit is 145°, give or take a couple. It doesn't matter whether it's tile, wood or carpet. The limiting factor is the stability of the gyp.
The Delta T for the Divicon is whatever you need it to be. With the multi-speed pump, I have Delta Ts from 10° to 25° depending on the application.
Warm Regards,
heatboy
"Expert in Silent Warmth"
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
